Forums >> Revit Structure >> Technical Support >> VG problems with uploaded beam family
Fri, Aug 24, 2007 at 7:19:19 PM | VG problems with uploaded beam family
chaggas
I have taken an existing structural beam family, (W-Wide Flange) and opened it for editing. I duplicated the file and then proceeded to edit it, rename it, and load it into my project. Everything worked out great!!!! EXPECT the visibility is a little different. I need the visibility of my beam to act like the visibility of the existing beams, especially when the visibility is set to “course.” This “course” setting is much liked by the engineers as it represents that of an analytical stick frame view. Attached is the beam file that I created. I’ve probably made a few fundamental mistakes. Any kind help and advice you can offer is much appreciated.
Fri, Aug 24, 2007 at 7:20:04 PM | VG problems with uploaded beam family
chaggas
I'm working with Revit Structure 2008
Fri, Aug 24, 2007 at 7:40:57 PM | VG problems with uploaded beam family
phildixon
1 Stars: 1 Votes
Have you set the Structural Usage to 'Girder' or 'Joist' etc? The stick line display wil depending on your selection.l differ
Fri, Aug 24, 2007 at 7:42:50 PM | VG problems with uploaded beam family
phildixon
1 Stars: 1 Votes
that should say 'will differ'!
Fri, Aug 24, 2007 at 8:46:36 PM | VG problems with uploaded beam family
chaggas
It was set to 'girder', but when I changed it to 'joist' nothing really changed. Do I have to reopen the family temp and change the selection there? I'll give that a try if I can.
Tue, Aug 28, 2007 at 6:49:43 PM | VG problems with uploaded beam family
chaggas
Okay, it worked. It needed to be set to "girder" and the family visibility needed to be edited in order to show up in the "course" view. Thanks phildixon!!!!
How do I add and image to uploaded family.
Mon, Apr 14, 2008 at 8:36:11 AM
Adding image to uploaded family
Fri, Nov 5, 2010 at 7:09:47 AM
Beam Problems
Fri, Sep 7, 2007 at 7:26:32 AM
How can I overwrite the object I have uploaded with a new version?
Wed, Sep 23, 2020 at 1:58:56 AM
Creating a beam family
Sun, Apr 17, 2011 at 9:06:00 PM
Page generation time: 0.9625
