Forums >> Revit Structure >> Technical Support >> Linking models, creating worksets, and coordinating views
Thu, Aug 23, 2007 at 4:50:46 PM | Linking models, creating worksets, and coordinating views
chaggas
First and foremost, here is a little background on me: I learned Revit 7.0 and 8.0 in an architectural basis. The project given to our class was to design a building in Revit and render it and well as create a walkthrough and presentation (3-4 weeks). Now I am working in the field with a company that is new to Revit and seriously looking to implement its uses. I am the one with the most Revit knowledge, so I am testing out the software features. I am using Revit Structure 2008 and Revit Architecture 2008. I need to know the major difference between "Linking" files and creating "Worksets". It seems that I would create worksets within one application of Revit  ( Revit Str. or Revit Arch.) and during a later phase of the design process. Right now I have linked the Revit Str. file to the Revit Arch file and I'm learning how to manage these links and how to use the "Share Coordinates" option. Any tips on this subject are definitely welcome. Hint: my boss wants everything to move with the grid lines. I’m thinking of creating coordinates that are on a grid line. Also, I need to know how to coordinate my views so that in Revit Str the non-load bearing walls appear. I need to know a proper way to link these files... if I open Revit Arch. and link the Revit Str. should I then do the same with Revit Str.?I will have more questions on creating complex family members and defining parameters on customized beams and columns. Please offer any assistance as I am new to this job and new to this software and a lot is being expected of me.
Thank You.
yes I posted this in the "newbies" as well, but I need I'm mainly working in Revit Structure and need the most help in this application.
Fri, Aug 24, 2007 at 10:23:36 PM | Linking models, creating worksets, and coordinating views
sdbrown
5 Stars: 3 Votes
Worksharing is for team work on either the structural model or the architectural.  Linking is just like xrefs in  cad with a few other features.  The basic work flow is the architect creates his/her model(it may or maynot have worksets depending on how many people work on the project or the project size). The struct. ngnr links in the architects model and uses copy monitor to grab any walls, grids, columns etc he wants to have control over in his model or see a notification when they are changed byt the architect.  Note you may want to create a workset for the arch model so you don't have to open it when you open your struct model(see selective open in the help).  Now you create your struct. model using the architects as a ref. then you send your model to him, he links it into his and the process keeps circling until the project is done.  When he moves a grid or wall you have copy/monitored when you reload the link you will be prompted it needs coordinating.  Many have found this annoying and decide just to model their own  stuff and use each others models purely as xrefs.
Thu, Aug 23, 2007 at 4:48:30 PM
Best Practices - Coordinating Column Grids Across Arch. and Structural Models
Wed, Nov 11, 2009 at 9:32:25 AM
Linking Models
Wed, Mar 5, 2008 at 3:22:34 PM
HELP! ALL of my plan views vanished!!!! I've tried creating new views
Wed, May 9, 2018 at 3:18:43 PM
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Page generation time: 0.5380
