Forums >> Community >> The Studio >> plywood
Sun, Jan 30, 2005 at 5:49:58 PM | plywood
bayou66
3 Stars: 1 Votes
I wood like to see if there is a family with a board or sheet of plywood that I can use to design casework (desks, entertainment centers, etc.) What would the experts suggest ? Any help is appreciated
Sun, Jan 30, 2005 at 7:03:40 PM | RE: plywood
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you actually want to go to that detail modelling!! Then simply create a new family that is a box, with parameters for width, length and thickness (set the material to plywood). Then just create new types to the appropriate sizes as you require... Personally though i wouldn't model to this detail and would just create basic solids to represent the elements then if you need more detail either embed detail components or drafting lines. HTH.
Sat, Feb 12, 2005 at 5:01:50 PM | RE: plywood
bayou66
3 Stars: 1 Votes
fantastic - I will give it a try - I have not done much at all with families - but I'm going to. Many Thanks
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
4' x 8' plywood representatiion in Revit (3d view)
Wed, Feb 10, 2010 at 7:42:33 AM
vertical plywood
Fri, Nov 25, 2011 at 8:26:44 AM
12
Need plywood panel
Mon, Dec 7, 2009 at 11:47:25 AM
Plywood under wall
Wed, Sep 3, 2008 at 7:39:52 AM
Page generation time: 0.0240
