14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> PDF's with Revit
It would really be important to create a way to insert pdf files into Revit and plot to PDF from Revit. If anyone knows how this can be done or will try to get a work around that would be great! Thoughts? Joe Lowe (619) 218-2841
11 Posts No Rating |
I'm not sure about importing PDFs, but a great free PDF plotter is at www.cutepdf.com
Thanks . . . I had just read about that in another thread and will try that. I also read that there may be a PDF to DWG converter which might work well for inserting PDF's. Thanks again, Joe
Your Welcome, Let me know how that PDF to DWG converter works out for you. That seems like it could be a very powerful tool. -Matt
I came across this a few weeks ago. Maybe its what you are looking for. http://www.autodwg.com/pdf-to-dwg-converter/
this is the program is use to convert pdfs to dwgs http://anydwg.com/pdf-to-dwg.html
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
If you have Adobe Illustrator there is an option to save to DWG. The only problem of course is that the lines in the PDF have to be directly generated by a vector (cad) program. If the PDF is created by a scan or someother method, the information contained is just an image anyway an you might as well convert the PDF to a Jpeg.
Thanks for the suggestion, but when I tried to use Adobe Illustrator and save to DWG, it looked fine until I brought it into REVIT then it lost all line quality. Maybe it is a setting issue for when I link it ito Revit, or could be the way it is being viewed. I take it you did not have this problem. Any ideas why that happened?
Probably for the reason that I lsited above. It is not vector information but raster information (an image). Can you open it in Autocad? You will be able to see if the lines are true Autocad lines or an image.
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Printing PDF's |
Tue, Oct 26, 2010 at 11:21:57 AM
pdf selections |
Sun, Oct 22, 2006 at 3:24:52 AM
PDF's & Excel |
Mon, Dec 12, 2016 at 6:17:38 PM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg. |
Wed, Aug 19, 2020 at 7:59:03 AM
