14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Interior Elevation Adjustments - things just aren't showing up!?!
20 Posts No Rating |
It's a simple thing really, I'm sure of it, I just can't figure it out. I have an interior elevation of a public restroom. I can't see the things right in front of me, like the toilet in the stallbut I can see it in the next stall, so it's not a visibility issue with the object being turned off. I can't see my sanitary napkin dispenser, but if I hide the toilet partition, I can see the one in the next stall. Little things like that. Anybody got any ideas? BTW, using revit 9.1 right now, in case that makes a difference.
Need more info. Try attaching some screenshots. It sounds like your elevation "Cut Line" is placed so the view is obscured by something else in the drawings (i.e. the partition). If that is the case you can select the elevation symbol and adjust the blue line closer to the objects.
Solved!! So sorry I didn't post this sooner... I ended up puting in "drafting" lines to show the missing objects but found out aa while later what the problem was. the Component was not made visible in elevation. At least not all parts of it. So if it happens to you, edit the component, then go to "visibility", and make sure the right items are set to be visible in plan/rcp, front/back, and left/right. It's worked to solve the problem with everything since.
Material window/options aren't showing! |
Mon, Dec 10, 2018 at 10:23:45 AM
pipes won't show up... |
Mon, Jun 15, 2009 at 1:36:08 PM
corner post on railings aren't showing up |
Mon, Apr 1, 2019 at 11:23:48 PM
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
Interior Elevation Tag missing from drop down |
Wed, Aug 18, 2010 at 4:28:45 AM
