Forums >> Revit Building >> Technical Support >> Faint Text Issue
Mon, Aug 20, 2007 at 8:24:25 PM | Faint Text Issue
puzzle
4 Stars: 10 Votes
One of the building companies I draft for use Simplex & Roman text. They have asked me to make the text darker/thicker so it is not as faint when they print it out. I know revit does not have line weights for text but I was hoping someone may know which text would look simplier but print thicker as they have used this text style for yaers and don't want to changed. I was hoping to avoid using bold to thicken the text.
Hope that made sense.
Macca
Sunshine Coast
QLD Australia
Tue, Aug 21, 2007 at 7:01:52 PM | Faint Text Issue
psymon
psymon Avatar
3.5 Stars: 6 Votes
We had the same problem using iso. You just have to hunt around for an acceptable font.
We use ISOCPEUR which has a thickness associated with it.
 Unfortunately Revit has a few problems when trying to make an office style (as you would know), arrowheads, elevation marks etc.
Faint lines showing from ground floor on first floor
Sat, Mar 10, 2012 at 4:40:33 PM
Text Line Weight
Sat, May 5, 2007 at 11:34:38 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Problems when printing tp PDF using shadows
Sat, Mar 21, 2020 at 7:41:02 AM
Text Scrambling Issue with Revit 2015 LT on Windows 8.1
Sat, Jun 13, 2015 at 11:17:05 AM
Page generation time: 1.1562
