Forums >> Revit Building >> Technical Support >> Importing A Revit Model
Mon, Aug 20, 2007 at 4:30:43 PM | Importing A Revit Model
Rabbit
I have been trying to import a Revit Building Model into my Revit Structure Model.  I have done this in the past a few times with good results; however, the latest model I am trying to do this with comes in 286'-0" below the true elevation.
I have tried different templates and get the same results; however, when I try someone else's model it works fine.
I will usually do this to copy/monitor the Levels, Grids, Columns, Walls and Floors.  This works really well for us, but at this point I am not sure what to do
This is a new client with whom I have not worked before with Revit, and it is a large project.
Any suggestions would be greatly appreciated.
Mon, Aug 20, 2007 at 8:56:35 PM | Importing A Revit Model
sdbrown
5 Stars: 3 Votes
Just move the project up or down to match your levels, or move your levels up or down to match his, then acquire coordinates from his model.
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ]
Sat, Apr 17, 2010 at 7:29:52 PM
19
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:43 PM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
Revit 2015 - Importing complex 3D DWG
Thu, Apr 30, 2015 at 7:14:45 AM
Page generation time: 2.1081
