Forums >> Revit Building >> Technical Support >> Buildable envelope using mass
Mon, Aug 20, 2007 at 3:54:49 PM | Buildable envelope using mass
MESSICKK
I am trying to create the buildable envelope for a hillside residential site.  I need to create a line up 15’ from existing grade and then back at 45 degrees at the front setback.  I have created the topo and a mass that encompasses the vertical setbacks.  How can I capture or create the line that is formed by the intersection of the vertical front setback and the topography at that point.  If I could capture that line (intersection), I could sweep the mass envelope using that line as a path (I believe) to create the true envelope. (revit Arch 200Shadey
BUILDING ENVELOPE
Fri, Nov 18, 2011 at 1:58:20 PM
Defining building envelope
Wed, Jan 7, 2004 at 6:03:36 AM
Curving a Truss to align with a mass
Fri, Oct 29, 2010 at 7:12:08 PM
Curving a Truss around an irregular mass
Sun, Mar 1, 2009 at 8:19:44 AM
BUILDING APARTMENTS
Sun, Apr 15, 2012 at 5:16:45 PM
Page generation time: 1.3023
