Forums >> Revit Building >> Technical Support >> Angled beam
Fri, Jan 28, 2005 at 9:22:26 AM | Angled beam
quiller
quiller Avatar
2.5 Stars: 3 Votes
I’m trying to mock up a beam connection where three roof beams come together and join. From this drawing we’ll create a drawing of the connection plates. Here’s the issue. I drew the roof and then in another project I created the main beam (11.25” x 3.5) with the create tool. I then imported the beam into the roof drawing, but the issue is I can’t rotate the beam to match the angle of the roof. Is there any way to create objects, either in a project or imported, so that it’s completely independent and can rotate into any position? Cheers……Alan
Mon, Jan 31, 2005 at 12:35:15 AM | RE: Angled beam
ale02
ale02 Avatar
3 Stars: 3 Votes
Not too sure about your problem but have you try to create family with an angular parameter? I have been facing problems in rotating in-place family too..maybe you can try to rotate your beams after you create the edit button first or even go into the sketch to rotate them.. Hope this helps!
Life is never easy but nor it should be complex. Just stay simple Smile
Mon, Jan 31, 2005 at 12:37:36 AM | RE: Angled beam
ale02
ale02 Avatar
3 Stars: 3 Votes
Correct to my previous reply..it should be "click" the eidt button rather than "create" the edit button
Mon, Jan 31, 2005 at 1:32:12 AM | RE: Angled beam
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There isn't a way currently to create free instance in all directions as you specified. you can however rotate a beam, but its not done by selecting the beam and rotating it, you have to rotate its associated work plane. This is why its always best to create a reference plane first associate it to this and then you can rotate the reference plane as desired. What you can also do, is, providing the element hasn't been disassociated, you can re-associate the element to any parallel work plane, ie a new reference plane, then rotate the reference plane. Don't quote me on this as it all sounds good in theory but i haven't tried it as yet. HTH.
Mon, Jan 31, 2005 at 8:27:34 AM | RE: Angled beam
quiller
quiller Avatar
2.5 Stars: 3 Votes
Hi all, Here's the scoop. What you have to do is use the roof tool to create the beams and then add another roof to cover them! That a look at the attached dwg and you'll see what I did. Cheers, Alan
Angled Beam Issue
Mon, Aug 26, 2013 at 6:09:39 AM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
angled corner joint - how to lock angled corners
Thu, Jul 18, 2013 at 5:10:11 AM
11
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Page generation time: 1.0654
