14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> copying level
26 Posts No Rating |
How can i copy or creat new level in revit structure? thanks in advance
Go to elevation, then under "Basics" click level draw it approxamatly wehre you want it. You can Rename it and change the elevations after you put it in. Doing this will add a new level in your structural plans and you will see the head is blue...if you were to copy "Level 2" up the head would be black and it would not be added to your structural plans, but is still a level, it just didnt create a floor plan for it. I mostly use the Level comand under basics. HTH Grant Doherty
thanks
copying lights issue revit 2016 |
Tue, Feb 27, 2018 at 5:01:37 PM
Copying floors |
Tue, Mar 9, 2010 at 10:04:35 AM
Copying Receptacle's |
Thu, Jul 13, 2017 at 11:50:36 AM
Copying from one file to another |
Sun, Dec 11, 2016 at 7:47:57 AM
Copying callouts across the projects |
Thu, Dec 4, 2014 at 9:59:11 AM
13
