Forums >> Revit Building >> Technical Support >> Plan Region problems
Fri, Aug 17, 2007 at 12:15:27 AM | Plan Region problems
lab21
I hope someone can help!
I’m trying to create a plan region that cuts the topography at a lower level to show how the building will be sitting partially under the ground line. But the region appears to have no effect on the topography in the view. I have attached a screen shot to help explain things. The first shot shows the view with cut plane set to 1400. The second view shows the cut plane at 700. And finally the third with a plan region set to 700 which appears to be doing nothing.
Is there a special trick I’m missing?
Any help would be appreciated.
Thanks in advance
Luke
Plan Region
Fri, Jul 21, 2006 at 4:23:10 PM
Revit MEP 2010 plan region HVAC problems
Wed, Sep 28, 2011 at 6:20:17 AM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
RA2008 Plan Region Removes Wall Detail Outside of Region [ 1 2 ]
Thu, Sep 18, 2008 at 8:19:25 AM
16
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Page generation time: 0.4817
