Forums >> Revit Building >> Technical Support >> section detail snaps on curved wall
Thu, Aug 16, 2007 at 3:07:02 PM | section detail snaps on curved wall
pgrimmi
i am cutting a section that includes a curved wall. i want to add detail components such as GWB and plywood but the components don;t snap to the point where the walls are cut. any suggestions?
thanks
pgrimmi
Thu, Aug 16, 2007 at 3:14:56 PM | section detail snaps on curved wall
broncos4life
3.5 Stars: 11 Votes
Either program that into your wall so when thoes materials of the wall are getting cut they look a certain way so then you dont have to use detail componants for GWB and plywood.  Or you can just eyeball it.  The only layer this usually wont work for is a stud layer.
dimensioning a curved wall's faces in section?
Sun, Jan 17, 2016 at 6:59:30 AM
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
Repeating Detail - Snaps don't work
Tue, Jan 25, 2011 at 9:33:15 AM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:56 AM
CMU wall reinforcement and detailing
Mon, Nov 22, 2010 at 1:32:03 PM
Page generation time: 1.0069
