Forums >> Revit Building >> Technical Support >> Phantom Surface pattern!!
Thu, Aug 16, 2007 at 12:01:41 AM | Phantom Surface pattern!!
Skoodles
Hi all
Using Revit Architecture 2008, i have modeled a building with two seperate roof structures, like a gable-end roof but one side is higher than the other (ie their ridge lines are not the same height)  I have used the same roof type for both...
My problem is that both roofs in elevation show the surface pattern but only one roof shows the pattern when printing or in a print preview... I have checked visibility settings, changed surface patterns etc to no avail! Has anyone come across this prob before?  Both elevation views are set up on the same sheet and it makes no difference if i was printing from the sheet or the individual view...
Any help would be greatly appreciated, Thanks Smile
Susan
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Page generation time: 0.9800
