Forums >> Revit Building >> Technical Support >> demolish door with out infilling opening
Wed, Aug 15, 2007 at 2:06:10 PM | demolish door with out infilling opening
burke424
In Revit 2008 is there a way to demolish a door and leave the opening? I need to demolish a door but still want the opening to remain but Revit automatically infills the opening when I demolish the door.
Wed, Aug 15, 2007 at 2:28:41 PM | demolish door with out infilling opening
TesterSH
You need to insert an "opening".  They are under "components".
Tue, Jul 13, 2010 at 7:03:37 PM | demolish door with out infilling opening
spacey
I have a similar issue, but with a window. I wish to demolish the window, retain the opening, and cut down the remaining wall below the existing window to create an new opening. I can create an opening in the wall as suiggested, but this cannot be assigned a phase, so doesn't seem an appropriate use. Should I create a separate wall up to the height of  the existing window lintel and demolish this?
I am not sure what the correct way to build one part height wall over another is.
-edit-I have ended up splitting the wall horizontally
Edited on: Tue, Jul 13, 2010 at 8:51:08 PM
Wed, Jul 14, 2010 at 2:00:16 AM | demolish door with out infilling opening
gebber
gebber Avatar
5 Stars: 4 Votes
Spacey, you could also try to insert a "window/door" wich only contains a void and cal this void opening.
Wed, Jul 14, 2010 at 4:50:10 PM | demolish door with out infilling opening
spacey
Thanks Gebber,
I'll do that.
Fri, Jun 5, 2015 at 9:30:39 AM | demolish door with out infilling opening
cjp5214
Bump.
I used the Cut tool and cut the infill section of the wall by the rest of the wall. It goes away instantly. Best part about it is I can still select the "hidden" infill section to uncut if I want to.
Hide infilling lines
Mon, Aug 22, 2011 at 2:51:33 AM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
Infilling elements containing sweeps
Wed, Mar 18, 2009 at 3:59:35 PM
Existing Door: demolish door, keep frame
Mon, Feb 7, 2011 at 2:13:59 PM
demolish dormeropening
Thu, Mar 22, 2007 at 5:50:49 AM
Page generation time: 0.2383
