Forums >> Revit Building >> Technical Support >> Help with Revit MEP
Wed, Aug 15, 2007 at 9:52:09 AM | Help with Revit MEP
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
I am currently designing an HVAC system in a trial building, however, I am unable to get the Actual Supply Airflow to change when i place my air terminals. This is very important because I have already created the schedule that I need for the construction documents. Ive read the entire section in the users manual, no help. somebody anybody pleeeeeease help.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, Aug 15, 2007 at 10:12:55 AM | Help with Revit MEP
Eddieboarder91
4 Stars: 8 Votes
ok so anyone who has a problem seeing the actual supply air, dont be stupid like me and spend hours racking your brain, its easy as changing the upper limit. as carlos says, im a deedahdee haha
Thu, Sep 10, 2009 at 10:48:22 AM | Help with Revit MEP
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
I have changed the upper limit for my spaces, however I cannot get my return air to show up in the "actual" column. The actual supply air shows up. The only difference that I can see, is that my return is a plenum return and is unducted. I tested this with an exhaust system in the same space. Unducted the exhaust will show in the calculated column, ducted to an exhaust fan, it shows up in the actual airflow. Since you conquered the original problem, have you got any thoughts on this? a plenum return is a fairly common system and I would like to schedule my air balance.
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
From 2D CAD MEP files to Revit MEP
Tue, Feb 9, 2010 at 11:12:10 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Page generation time: 2.3396
