Forums >> Revit Building >> Technical Support >> Re-referencing Elevation Tags - Revit Architecture 2008
Mon, Aug 13, 2007 at 5:17:32 PM | Re-referencing Elevation Tags - Revit Architecture 2008
Revit23
3.5 Stars: 2 Votes
I need to relocate the elevation tag from one view to another.  I don't care if they show up in both, I just want to relocate the elevation marker from one plan to the same place on another view of the same plan.  I know that going to View and selecting Elevation will create another elevation all together.  I do not want to reference another elevation as it will appear as "SIM"... so any suggestions?
 All expertise is greatly appreciated!
Tue, Aug 14, 2007 at 8:22:14 AM | Re-referencing Elevation Tags - Revit Architecture 2008
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Your elevations should show up unless they have been turned off. Check the Visibility/Graphics and make sure they are not hidden in the view.
Tue, Aug 14, 2007 at 8:47:36 AM | Re-referencing Elevation Tags - Revit Architecture 2008
Revit23
3.5 Stars: 2 Votes
Thanks.  I'm actually gong to answer my own question: REMEMBER TO DOUBLE CHECK THAT ANOTHER TEAM MEMBER HASN'T PLACED ANOTHER ELEVATION TAG DIRECTLY OVER THE ONE THAT ALREADY EXISTED.  Unfortunately, I had given up and re-created the elevation by the time I'd found the duplicate.  It's all a learning process, er something. Smile
REVIT 2008 Changing tags!!!
Mon, Aug 27, 2007 at 12:25:02 PM
Changing elevation tags to Shared Coordinates
Thu, Aug 20, 2009 at 8:59:54 AM
elevation tags
Tue, Jul 1, 2008 at 2:27:02 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:43 PM
Getting started
Sat, Mar 22, 2008 at 2:47:59 AM
Page generation time: 1.5300
