Forums >> Revit Building >> Technical Support >> Attaching a wall to underside of stair stringer
Sun, Aug 12, 2007 at 1:31:03 PM | Attaching a wall to underside of stair stringer
CourtneyQ
Is it possible to attach the top of a wall to the underside of a stair stringer (i.e. the stair stringer is resting on the wall, therefore, the top of the wall slopes with the stair)??
Sun, Aug 12, 2007 at 5:20:05 PM | Attaching a wall to underside of stair stringer
puzzle
4 Stars: 10 Votes
Draw a section along one side of the stairs. Go to the section. Draw a reference plane on the same angle as the stringer. Click the wall and attach top to the reference plane.
Macca
Sunshine Coast
QLD Australia
Fri, Nov 16, 2007 at 7:18:39 AM | Attaching a wall to underside of stair stringer
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
This tip is good, but how I can clean the joint between the stair and wall, like clean geometry; wall and floor?
Fri, Nov 16, 2007 at 11:18:13 AM | Attaching a wall to underside of stair stringer
ebtaylor
3 Stars: 2 Votes
use the linework tool to make the line at the top of the wall invisible!
Fri, Nov 16, 2007 at 11:20:48 AM | Attaching a wall to underside of stair stringer
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
thanks
Fri, Jul 18, 2008 at 10:54:01 AM | ebtaylor
cganiere
cganiere Avatar
Thank you. Good tip.
Quoting ebtaylor from 2007-11-16 11:18:13
"use the linework tool to make the line at the top of the wall invisible! "
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Connecting walls to stringers / hiding treads and risers
Thu, Nov 18, 2004 at 1:20:38 PM
Curved Wall Under Stair and Edit Curved Wall Profile
Mon, Apr 19, 2010 at 5:06:40 AM
Attaching walls to stairs
Tue, Aug 22, 2017 at 12:20:10 AM
13
underside of stair
Tue, Jun 24, 2014 at 9:17:50 AM
Page generation time: 2.0397
