Forums >> Revit Building >> Technical Support >> imported dwg lineweights, linetypes
Thu, Aug 9, 2007 at 4:10:50 PM | imported dwg lineweights, linetypes
SWsam
after I import a CAD detail I can choose the lineweghts and linetypes(pattern) for layers under visibility graphics.  I have to do this for each drawing.  I know I can setup lineweights for layer colors under file>import/export settings>import lineweights dwg/dxf, but not linetype(pattern).  Is there somewhere to input default info for lineweights and linetypes for all imported CAD dwgs? - basically have the inputs under visibility graphics apply to all dwgs upon import.
SWsam
Fri, Aug 10, 2007 at 9:22:53 AM | imported dwg lineweights, linetypes
sdbrown
5 Stars: 3 Votes
The linetype should come in as what the linetype is in cad. If you need to change that it has to be per layer or done in acad before you bring it in.
Looking For Easy Way to Control Lineweights When Linking DWG Files
Fri, Jan 18, 2008 at 3:17:58 PM
Imported DWG line types not visible
Wed, Mar 12, 2008 at 4:24:08 PM
DWG Revit export replacing linetypes with erronous linetypes
Tue, Mar 17, 2015 at 10:07:42 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Revit 2015 - Modify DWG/DWF Export Setup - Linetypes
Wed, Mar 2, 2016 at 3:02:28 PM
Page generation time: 0.9459
