Forums >> Revit Building >> Technical Support >> Imported Details from AutoCAD coming into Revit Black Out!?
Thu, Aug 9, 2007 at 12:35:42 PM | Imported Details from AutoCAD coming into Revit Black Out!?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Like the title says, I'm importing some text that goes along with some details from AutoCAD to Revit Architecture 2008 and instead of showing the insulation and other detail components its coming in all blacked out... any ideas?  Can I import this onto a detail view or into a legend?  This is really annoying all the text comes in perfect.
Thanks for any help.
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Thu, Aug 9, 2007 at 5:05:25 PM | Imported Details from AutoCAD coming into Revit Black Out!?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Anybody know a better way to get details into Revit from AutoCAD?
 LHAA
Reno, NV USA
Thu, Aug 9, 2007 at 6:56:29 PM | Imported Details from AutoCAD coming into Revit Black Out!?
psymon
psymon Avatar
3.5 Stars: 6 Votes
It may be an issue of linetype thickness?
The best way to do this, if they are standard details to be used agin is to make a new detail family, import the autocad detail then load that into your project.
There is a file accesable under the file menu - import/export settings/import line weights-dwg
This file maps the Autocad colours to Revit Line weights, you should customise this to your office standards. This will apply to autocad drawings directly imported into your project or into families.
Fri, Aug 10, 2007 at 1:04:51 PM | Imported Details from AutoCAD coming into Revit Black Out!?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Ok I'll see what I can do.  Thanks, for now I just redrafted the details and what not in Revit so it wasn't that bad. =)
 LHAA
Reno, NV USA
Autocad details with hatch showing as black/solid
Wed, May 22, 2013 at 11:47:29 AM
Rendering is coming out black
Fri, Aug 1, 2014 at 9:06:25 AM
LInked AutoCAD details into Revit 2009 workset project
Tue, Jun 28, 2011 at 5:07:32 PM
Black background on text (imported DWG)
Thu, Feb 18, 2016 at 8:38:47 AM
Importing .dwg details
Wed, Jul 12, 2006 at 12:23:47 PM
Page generation time: 3.1256
