9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> I want to know how can I calculate the total cost with revit???
I want to know how can I calculate the total cost with revit??? and also there is big trouble in revit that in the type parametres there is the cost parameter in the walls paramteres and I couldnt apply any formula in this paramtere because I want to calculate the cost by (cost=lengthx500$)for example ??? and so on for the other elemnts???
Don't use this cost parameter.
In the wall schedule choose calculated value and name it cost per metre (add your own regional setting)
Then select the type to be a number.
Now we need to add a formula:
(Length/1000)*500
This will effectively calculate the cost per metre for each stretch of wall.
Now in sorting and grouping tick grand totals. Title, count and totals.
Then in formatting select your newly created parameter and then tick calculate totals.
THat should do it.
HTH.
I prefer to create another parameter for unit rate (in this case the 500$) in the formula so that I can incorporate different rate for different type of wall.
the formula in this case would be (Length / 1000) * unit rate
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
2 Posts No Rating |
For materials, I use the material's cost parameter with the families area parameter. Just remember how the cost relates to area i.e. cost per sf or square yard. Process - Add the Material: Area field and Material: Cost field to your schedule.
- Make a Calculated field called total cost as a currency field.
- Enter the formula: Material: Area/ 1 SF * Material: Cost
- The key here is to cancel out the area unit so you get a consistent currency unit.
- Also remember that there is a space after the colon.
This applies to any assembly cost or unit cost as well. Cancel out the units.
1 Posts No Rating |
This applies to any assembly cost or unit cost as well. Cancel out the units. i tried this but since i'm using metric i placed m² but it said inconsistent units how do i cancel the square meter already tried SQM still didn't work
1 Posts No Rating |
for metric, use 1 m2 not 1 SF ...note the space between 1 and m2. otherwise it throws an error
Hello,
This thread was really helpful as I was having a inconsistent units error.
Still, The calculated value column turns empty after I type the Material:cost anything different than 0.
Why could this be happening?
many thanks
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
total cost |
Mon, Jan 17, 2005 at 5:35:00 AM
Calculating two Formulas on the same row in a Schedule |
Thu, Dec 16, 2010 at 10:04:47 AM
Area Schedule Estimated Cost |
Fri, Aug 21, 2009 at 10:09:35 AM
Total Cost Estimate (detailed) |
Fri, Sep 12, 2008 at 12:13:12 PM
Material cost per sq ft formula |
Mon, Sep 21, 2009 at 9:06:24 AM
