16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> Eliipse Wall
2 Posts No Rating |
Hello!!! I'm trying to create an elliptical wall and i can't. I tryed using masees and i had no result at all. Can anyone help me??????????????????
Sorry, but you need to provide more information. Using masses should work. Please outline your attempted method and where it "failed"
1 Posts No Rating |
I agree with psymon. Use masses. Give more details please .
Edited on: Fri, Aug 10, 2007 at 5:01:39 AM
----------------------------------- There is always a better solution. |
If you don't need multiple layers the easiest thing is to do an inplace wall family and extrude the shape you want. I prefer to construct ellipses with 4 arcs( draft using the line tool your ellipse) then trace with the arc tool(wall) a 90deg end segment , mirror that and then use the tangent arc tool to connect the dots, this gives a buildable wall assembly that you can dimension and turn on the center points.
Floor - line artifacts in PDF |
Tue, Jun 11, 2013 at 2:02:30 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
create a wall sweep on an angled wall (gable end wall) (2017) |
Wed, Aug 3, 2016 at 2:29:53 PM
wall mounted toilet wall error |
Wed, May 6, 2009 at 3:41:37 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:44 PM
19
