Forums >> Revit Building >> Technical Support >> File corruption issues
Wed, Aug 8, 2007 at 10:48:18 AM | File corruption issues
Jtouchstone
5 Stars: 2 Votes
Revit 2008
When I try to open the company template to work on it I keep getting a error:
An attempt was made to access JA Project Template.rte past its end.
Does anyone know what causes this type of error. This is not the first time with this file.  I have backups but I will loose a days work going back.  I would like to stop this from happening so any help would be great.
Thank you.
Wed, Aug 8, 2007 at 11:53:04 AM | File corruption issues
If you'll serach the forum with "past its end", you will see several posts on this subject.  None have a good answer.
Issues Upgrading Revit File
Fri, Jul 12, 2019 at 4:26:06 AM
Design Options Error
Wed, Dec 2, 2015 at 4:22:03 PM
Possible Corruption in 9.1
Thu, Sep 28, 2006 at 10:48:29 AM
12
Accessing Central File Issues
Fri, Sep 28, 2012 at 7:12:14 AM
12
Central File Syncing Issues
Sun, Mar 11, 2012 at 5:34:27 PM
Page generation time: 1.2709
