9 Users Online (7 Members):
Forums >> Revit Building >> Tips & Tricks >> Schedules - Costings
20 Posts No Rating |
Had a couple of people ask me how to create a schedule of furniture including count, unit cost and total cost of each group of items....Revit has the issue that the Count field can't be used within a formula http://www.revitup.co.za/_mgxroot/page_10833.html Justin
2 Posts No Rating |
I'm trying to make a very simlar schedule for signage as in your example. I understand the need to add the addtional field, but what formula is in the Cost field and how do you get the totals in the footers?
Marcia, In order to get totals in your schedules you need to edit the table and under the Formatting tab, tick the Calculate Totals for the required field you wish to total up. Then go to the Sorting and Grouping tab and tick Grand Total here as well (selecting Count and Totals, or Totals only depending on what you wish to do). Regarding the formula. This needs to be added to the Fields tab through the Calculated Value button. It's up to you what formula you wish to enter, but if you are for example mutiplying to fields then you must enter the field description exactly as it is listed. My formula for the material area was: Material: Area * Material: Cost / 1^ M2 Add the cost of your signs into the family through the Type Properties and then you table will able to pick the cost filed up. I hope that this helps. Justin
2 Posts No Rating |
Thank you. This did help, I wal just missing the formatting tab and the calculate total. I knew it was something simple. Marcia.
So does that mean you have to edit the properties and add a cost for every item?
29 Posts No Rating |
Hi, I read the message that you sent al long time ago. I wondered if you have solved the problem of using "count" in a formula. I want to calculate the total cost of furniture without haing to list all the individual items. If you have a solution, I would like to hear it. Eveline
You don't need to add count. Try this experiment. - Have a cost assigned to all your furniture.
- Create a furniture schedule - just two fields - family and cost.
- For the cost field under formatting, check the cost field.
- Under sorting and grouping, uncheck itemize every instance.
- Hide the family field.
You should end up with a schedule that gives you the total cost of all your furnishings. Now you can modify this to sort / filter as you need.
multiple schedules |
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA |
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets |
Thu, Apr 27, 2006 at 11:01:59 PM
Large number of schedules |
Mon, Jun 20, 2011 at 12:56:18 PM
Area Schedules showing Metric and Imperial |
Thu, May 28, 2009 at 11:49:29 AM
