8 Users Online (6 Members):
Forums >> Community >> The Studio >> Using escalators
2 Posts No Rating |
does anyone have a good escalator family, or any info on using any of the ones available for download
heres the one I use, just input the proper floor to floor hieght, etc.
2 Posts No Rating |
Thanks, is it easy to adjust some of the dimensions to resize the distances from riser to edge support to more accuratly reflect specific suppliers specs?
5 Posts No Rating |
Our fully parameterized Escalator Revit® Family has been released and is available for download at http://www.revit-content.com/content/00-01-5514061-Escalator.htm 30 flexible ParameterYou have 30 possibilities to setup your Escalator to every available Escalator. With just one Family you have thousands of possibilities to get exactly the Escalator you need for your Project.
Choose your AngleOne of this 30 Parameters is the Angle of the Run. The Family is fully parametrised - that means that you just need to change the Parameter for the Angle for example to 30° or 35° (or every angle you would like) and you have automatically your Escalator (even the Steps adjust automatically accordingly to the Angle, Height of Level, etc.)
You want to see always a correct Floor Plan ?No Problem at all - This fully parametrised Escalator Family shows the Model corect cutted and even the hidden Lines for the Model above thecutting Line is fully parametrised.
How to set up parameters for escalators |
Tue, Sep 27, 2011 at 7:31:37 AM
Escalatores stairs |
Tue, Aug 1, 2006 at 11:17:56 AM
Editing height of escalator? |
Fri, Mar 6, 2009 at 3:06:54 PM
Stair Cut Lines |
Sat, Nov 5, 2011 at 8:24:35 PM
Central model - extract object with Project Base Point |
Fri, Sep 20, 2013 at 2:15:32 AM
