28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Custom Ceiling Grid
20 Posts No Rating |
Fistly, I can't seem to find where the default ceiling families are stored - they're are a couple default families stored in my project but i'd like imperial versions of them loaded. Where are they located? And, how do I go about creating a custom acoustic tile ceiling grid pattern - i need a pattern that has 1-1' tile sandwiched between 2-2' tiles? I can't seem to edit the Compound Ceiling: 600mm x 1200mm grid. I've tried using the ceiling template tool with no luck. Thanks! Silva the newbie.
I'm sure there is a better way, but... I would make multiple ceilings for each tile size. So, make several ceilings in the same room. It should work out fine.
Light fittings in ceiling grid |
Tue, Feb 8, 2005 at 6:33:49 PM
Ceiling Grid |
Wed, Mar 16, 2011 at 3:15:50 PM
Ceiling Grids in Revit 2011 |
Fri, Jul 22, 2011 at 8:35:24 AM
rendering ceiling grid |
Wed, May 16, 2007 at 1:37:31 PM
Can we create our own ceiling grid? |
Mon, Jul 11, 2011 at 8:35:01 AM
