Forums >> Revit Building >> Technical Support >> High window visibility in plan
Mon, Aug 6, 2007 at 5:21:09 PM | High window visibility in plan
t1slc
I have a window that is above the cut plane of a floor. However, I want to show the location of the window on the plan. Is there a way to do this with visibility or view range settings? If not, does anyone have a good suggestion how to do this? I tried model lines, but they get over drawn by the wall and don't show up.
Thanks for any help.
Mon, Aug 6, 2007 at 9:01:28 PM | High window visibility in plan
sdbrown
5 Stars: 3 Votes
YOu use a plan region.  Go to the view toolbar, click plan region draw a box where the windows are. Then select the properties of this and adjust the view range. this affects just this area.
Wed, Aug 8, 2007 at 5:49:36 PM | High window visibility in plan
t1slc
While the plan region worked fine, I came across this as I continued working. See attached files.
Here are two different windows, both above the cut plane. One window shows in the plan, while the other does not. I've attached the plan views and the section views as well as my view range settings. Can anyone explain? I would prefer the windows above the cut plane to show as they do in the view that you can see them, as opposed to making a view region.
26560_above_cut_windo1.jpg26560_above_cut_windo1-2sec.jpg26560_above_cut_windo2.jpg26560_above_cut_windo2-2sec.jpg26560_view_range.jpg
Wed, Aug 8, 2007 at 5:53:45 PM | High window visibility in plan
t1slc
sorry for the poor images, I'll work on some better ones.
Wed, Aug 8, 2007 at 5:59:45 PM | High window visibility in plan
t1slc
Here are better images...
26562_windo_above_cut_1_sect.jpg26562_windo_above_cut_1.jpg26562_windo_above_cut_2_sect.jpg26562_windo_above_cut_2.jpg
Window Visibility in Plan View
Wed, Apr 20, 2016 at 9:31:05 AM
14
Showing High Windows Cut In Plan
Mon, May 28, 2007 at 3:09:47 PM
Cheating a Floor Plan Cut
Mon, Jul 26, 2010 at 5:53:23 PM
window head showing in floor plan [ 1 2 ]
Fri, Apr 29, 2011 at 1:51:22 PM
16
SECTION CUT VISIBILITY ISSUES WITH WINDOWS
Wed, Feb 3, 2016 at 11:28:10 AM
Page generation time: 0.5237
