Forums >> Revit Building >> Technical Support >> revoled families
Tue, Dec 23, 2003 at 8:06:32 AM | revoled families
Bimman
Bimman Avatar
1 Stars: 2 Votes
i have made 3 round columns 8,10,12 inch. each are a seperate family that i can adjust the hieght of with parameters, by making a profile of the column then revoling it about the axis. my question is could i have made 1 family then made the 8,10,12 inch column from that rather than 3 seperate families. i didn't know if a revolution could be changed in the family itself. can set parameters for the base of the column,which is square in shape but not the width of the revolution. am i correct in how i have created the families.
Tue, Dec 23, 2003 at 9:18:09 AM | RE: revoled families
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
you can set a parameter for any dimension in your family, whether it be the width of the base or the radius of your round column. If the profiles of your columns are the same, you probably could have created them in just one family.
Hiroshi Jacobs
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Rendering Families in Revit 2010
Mon, Jul 19, 2010 at 5:39:45 AM
Page generation time: 0.2201
