15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> dOORS AND DOOR SCHEDULES
Does anyone know how not to schedule doors? For example I have a big gym complex that I have built in revit- I am only adding on to a small area of this complex and only want to schedule the new doors germane to my project- however all the doors in the project are showing up in shedule- I thought I had it figured out as I was able to split the schedule at the point where it goes to existing doors and I moved that off the sheet but when I go to print it of course prints the sheet and the schedule scaling the whole thing to fit on the standard sheet size aaarrggh.
I would suggest using a filter on the schedules. I had to do this once when I didn't want to schedule a specific set of doors. What I did was to enter "Do Not Schedule" In the Comments parameter of each of the doors I didn't want to schedule. I then created a filter in my door schedule that filtered out all doors with that as the value of the comments. Worked great.
What JAMESHGRIMES has suggested will work but I think everything in your project will work better if you assign your elements to different phases and filter / VG all views accordingly. By doing this, you can create existing plans / demolition plans and on new plans, show existing differently than new work.
I agree with WWHUB. I just haven't worked with phases very much so I wasn't sure if that was the fastes method or not.
identical doors in a door schedule |
Tue, Nov 22, 2011 at 8:12:04 AM
Schedules: Ie Door schedules! |
Fri, Jul 11, 2014 at 2:58:22 PM
Nested Door Families and Door Schedules |
Mon, Nov 8, 2010 at 2:56:46 PM
Customizing Door Schedules |
Wed, Jun 3, 2009 at 9:05:57 AM
Door Schedules - Revisions |
Fri, Nov 12, 2010 at 4:10:09 PM
