Forums >> Revit Building >> Technical Support >> pat files
Fri, Aug 3, 2007 at 10:21:52 AM | pat files
morss
How do I get a pat file for a standing seam roof loaded into my project and make it appear on my roof in a perspective?
Morss Medical Architecture
Fri, Aug 3, 2007 at 11:57:54 AM | pat files
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you alread have a .pat file you can:
Go to Settings-->Fill Patterns
Click the Model radio button at the bottom of the dialog
Click New-->Custom-->Import
Browse to the .pat file and open.
You may have to enter a scale to get the correct spacing.
After you have created the fill pattern you will need to apply that pattern as a surface pattern in your roof material. It should then show up in all views (3d and 2d) where the roof is shown.
Fri, Aug 3, 2007 at 1:58:32 PM | pat files
morss
Thanks for your input. I did all you said but cannot get any pattern to appear on my roof. I have tried many of the pat model files but nothing shows up in elevation, 3D or rendered perspective. I can get a surface pattern from the drafing file to work but not a model pat.
Fri, Aug 3, 2007 at 3:21:04 PM | pat files
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
That is strange. The only other thing I can think of is to check the visibility/graphics dialog and see if surface patterns are turned off for roofs.
Fri, Aug 3, 2007 at 6:20:43 PM | pat files
morss
There must be something wrong with my pat file. I have figured out how to get the surface pattern to work for the drafting type and most of the model typed but not the standing seam. I changed the scale to as large as it would go and if I zoom way in on it I can see the pattern. Got any ideas where to get a better standing seam file?
Mon, Aug 6, 2007 at 9:03:20 AM | pat files
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Try this one that I made. It is a simple pattern but it works.
Mon, Aug 6, 2007 at 4:36:54 PM | pat files
morss
Thanks, that works great, except in a rendered perspective. How do I get it to do that trick?
Mon, Aug 6, 2007 at 5:07:09 PM | pat files
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You will have to come up with a material image that has the lines on it. When rendering the material image takes over.
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files
Fri, Oct 21, 2005 at 3:13:23 PM
Page generation time: 4.5798
