Forums >> Revit Building >> Technical Support >> Colorbond wall_section structure...HELP!!
Thu, Aug 2, 2007 at 9:22:01 PM | Colorbond wall_section structure...HELP!!
stylewise
Hi there, I am after some help/advice on creating a 125mm thick wall consisting of 70mm timber stud, 35mm timber batten and then 20mm Colorbond steel horizontally? I know how to make it look like colorbond with patterns but would like to actually create structure in section view of curved profile of the steel fixed to the timber batten...Thankyou
Sun, Aug 5, 2007 at 11:30:19 PM | Colorbond wall_section structure...HELP!!
puzzle
4 Stars: 10 Votes
You could use a sweep or an extrusion to make the colorbond. The only problem is that it makes the file size of your project rather large and will probably slow down your work rate.
Macca
Sunshine Coast
QLD Australia
Colorbond Roof
Sun, Nov 9, 2014 at 8:25:25 PM
snapping to wall structure
Thu, Apr 10, 2008 at 3:35:37 PM
creating own wall family
Tue, Jul 24, 2012 at 7:08:19 AM
Materials for 3D / Render
Wed, Sep 7, 2011 at 1:49:35 AM
how to dreate a double gable ended roof on a square structure???? [ 1 2 ]
Fri, Mar 13, 2009 at 7:42:49 PM
25
Page generation time: 0.0925
