Forums >> Revit Building >> Technical Support >> Wall Visibility in 3d structure view
Thu, Aug 2, 2007 at 7:34:42 PM | Wall Visibility in 3d structure view
patdelahunty
I use a 3D Structural view which has only structural components visible. I have made an appropriate template for this purpose. I cannot see my lift shaft walls because I have set walls to be not visible. Can I make a new category (wall or structure) for the lift shaft and include it in my view? I don't want to cheat und make it as a floor! Is there a better solution?
 Using Revit 9
Mon, Aug 6, 2007 at 1:13:55 PM | Wall Visibility in 3d structure view
cluttermonger
If your shaftwalls had a unique word in their name (like "shaftwall"Winking  then you could create a filter (pulldown menu... Settings/Filters) that includes only objects with the word Shaftwall in the name.  This filter then can be used in your view properties to make the shaftwalls visible.(View properties/Edit visibility graphics/ filters)
Hope that helps.
Structure visibility of multilayer elements such as walls and slabs.
Wed, Dec 18, 2013 at 8:34:23 AM
Window UN/Visibility in Revit Structure
Tue, Jun 7, 2011 at 5:40:41 AM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
snapping to wall structure
Thu, Apr 10, 2008 at 3:35:37 PM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
Page generation time: 2.7128
