19 Users Online (17 Members):
Forums >> Revit Building >> Tips & Tricks >> REVIT & SKETCHUP
DOES ANYONE KNOW IF I CAN EXPORT MY REVIT MODEL INTO SKETCHUP?
via dwg exporting.
does this work the other way around? Eg. SketchUp to Revit?
you can bring SketchUp models directly into Revit. There are certain thing that won't import, but the pure SketchUp stuff will import HTH
2 Posts No Rating |
so when you move from REVIT to sketchup... you export as a 2007 DWG... then do you have to take it into AutoCAD and export it again or something? When I try to take the file straight from REVIT to SketchUp all I get is flat linework and no 3D masses... did I miss a step?
Did you export to dwg from a 3D view? It can't be from a plan.
When in Revit( a 3D view), go to file export cad format. Then change it to a 2004 cad file and then go into the options. Under solids, make sure it says "Export as ACIS solids" Click ok and then save. Now open sketchup and import your cad file and it should work. JB
You want to export a 3d view and I would recommend using polymeshes instead of acis solids. sketchup and viz use polymeshes best, autocad does both alright.
1 Posts No Rating |
why when i import a skp file to revit and i render tha object comes up in white and not w the texture and color that the object has? is there a spacial seting i have to do to render skp files?
Sketchup to Revit material problem [ 1 2 ] |
Wed, Jun 30, 2010 at 11:58:37 AM
26
Sketchup to Revit |
Wed, Aug 26, 2015 at 10:41:27 AM
Furniture Tags & Sketchup Furniture Components |
Fri, Dec 4, 2015 at 9:35:33 PM
Sketchup model into Revit |
Tue, Jan 8, 2013 at 12:06:20 PM
Warthog |
Mon, May 7, 2012 at 11:37:13 AM
