Forums >> Revit Building >> Technical Support >> Dormer Rake Edge
Wed, Aug 1, 2007 at 4:45:03 PM | Dormer Rake Edge
t1slc
Another rookie question...What is the best way to create dormer rake edge walls? See attached image for reference. As you can see the change in roof pitch creates the triangular areas that don't have  walls, but there is not a wall in the room below. Does anyone have a good way to fix this?
Thanks.
Wed, Aug 1, 2007 at 5:20:39 PM | Dormer Rake Edge
broncos4life
3.5 Stars: 11 Votes
Make a wall, attach the top to the upper roof, then in elevation edit the profile of the base to match the slope of the lower roof.
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:00 PM
How can i get a dormer on this type of roof?
Wed, Mar 14, 2012 at 2:58:37 PM
Dormer wall attachment issue
Fri, Apr 15, 2011 at 1:42:00 PM
DORMER ROOF
Sun, Mar 20, 2005 at 6:46:00 PM
Dormer Opening Not Defined?
Wed, Feb 23, 2011 at 7:53:40 AM
Page generation time: 0.0842
