Forums >> Revit Structure >> Technical Support >> curved beam in revit structure 2?
Wed, Aug 1, 2007 at 11:44:25 AM | curved beam in revit structure 2?
manifertal
manifertal Avatar
How can i make curved beam in RS2?
thanks in advance
Wed, Aug 1, 2007 at 12:02:51 PM | curved beam in revit structure 2?
broncos4life
3.5 Stars: 11 Votes
Create componante in place, then use a sweep with a profile of the beam.
Wed, Aug 1, 2007 at 2:32:57 PM | curved beam in revit structure 2?
manifertal
manifertal Avatar
can you explain clearer.
Wed, Aug 1, 2007 at 3:29:55 PM | curved beam in revit structure 2?
broncos4life
3.5 Stars: 11 Votes
Basic Tab -> Component   then up on Properties tool bar click "Create In Place"  Then choose what family category you want it in, probably "Structural Framing."   Then click "Solid Form" -> Solid Sweep.  Draw the curve that you want by either sketching the 2D path or picking  a path.  Then load the profile of the beam from the library "Load Prifile"  and finish the family.
Thu, Aug 2, 2007 at 12:49:21 AM | curved beam in revit structure 2?
manifertal
manifertal Avatar
Thanks a lot.but when i try to load from a family(structural ->framing->steel beam),an error sign comes up->Cryinga family is not of the correct category)?
Thu, Aug 2, 2007 at 5:28:22 AM | curved beam in revit structure 2?
manifertal
manifertal Avatar
Thanks broncos4life i found my answer completly .
Mon, Nov 10, 2008 at 10:43:12 AM | curved beam in revit structure 2?
lepham
I am running into the same problem with Revit architecture 2009. It kept saying "the family is not of the correct category". manifertal, how did you figure it out?
thanks,
Fri, Dec 5, 2008 at 12:50:04 PM | curved beam in revit structure 2?
dasfinfo
Thanks broncos4life. That was very helpful.
complex curved roof structure
Thu, Mar 12, 2009 at 1:11:49 PM
curved concrete beam
Fri, Oct 17, 2008 at 6:10:21 PM
curved beam
Thu, Jul 20, 2006 at 5:52:48 PM
Curved Glulam Beams
Thu, Jun 3, 2010 at 3:38:46 AM
vertical curved beam
Wed, Sep 5, 2012 at 10:55:57 AM
Page generation time: 1.4647
