14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Creating Space Frames
1 Posts No Rating |
I was wondering if there was a (relatively) simple way to create a space frame structure.
A specific point of concern is defining the connections between joints. I suppose the joints would actually be drawn in a detail view, however, some sort of connection place holder would be nice to have appearing in the standard views.
Any suggestions that could be offered would be greatly appreciated.
3 Posts No Rating |
Ive been trying to do the same thing, I ended up using braces/beams from the structural tab, I just loaded a steel rod modified its thickness and started connecting them with 3d snapping turned on. for the connection i jus added a sphere to a brace/beam family i created Hopefully this helps, if you find a better way please let me know
JC Moreno UM SOA |
Inner space is not surrounded by outer space with higher height. |
Thu, Sep 6, 2012 at 8:34:57 AM
Revit Walkthrough; between key frames |
Thu, Jul 30, 2015 at 8:22:01 AM
help with creating plenum space - MEP2011 |
Wed, Jun 23, 2010 at 5:00:49 PM
Creating frames for details and having them not print |
Thu, Feb 15, 2018 at 12:05:02 PM
REVIT MEP 2011 - Duct union/TDF/TDC 35mm Frames |
Sun, Sep 2, 2012 at 5:15:18 PM
