Forums >> Revit Building >> Technical Support >> CHANGING A BEAM(S) WORKPLANE
Tue, Jan 25, 2005 at 1:00:15 PM | CHANGING A BEAM(S) WORKPLANE
nathanj
Once a beam or series of beams is placed, how can I edit its properties to change the beam's workplane (reference level)? The pull-down meno in the properties dialog is inactive. Even if I detach the beam from the column it still will not change levels. Post edited on 2005-01-25 13:00:23
STRUCTURAL COPING
Tue, Oct 4, 2011 at 11:25:09 AM
beam finishes
Wed, Sep 19, 2012 at 3:11:30 PM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Beam system not sitting on beam
Thu, Jan 3, 2013 at 11:40:10 AM
Beam System Visibility
Wed, Mar 22, 2006 at 9:23:08 AM
Page generation time: 0.1658
