Forums >> General Discussion >> Wishlist >> break gridlines
Mon, Jul 30, 2007 at 10:30:04 AM | break gridlines
Macy
It would be helpful to have the ability to break a gridline in the center in certain views, similar to section cuts, in order to unclutter an elevation drawing but still be able to reference levels.
Mon, Jul 30, 2007 at 10:39:48 AM | break gridlines
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can toggle the 3D/2D extents of gridlines. Select a gridline and you will see a "3D" tag next to the control. If you click this tag it will change to "2D" and allow you to move that endpoint independantly for that view only. As breaking a gridline between the head and the endpoint, I don't think that is possible at this time. HTH
Mon, Jul 30, 2007 at 10:53:26 AM | break gridlines
Macy
great, that might be just what we need to do for this project but I do think it would still be helpful if the break function could be incorporated into the gridlines in the program.  Thanks a lot though!
Tue, Jan 8, 2008 at 10:02:10 AM | break gridlines
JHanby
3.5 Stars: 3 Votes
I agree with Macy, it would be good to be able to break gridlines to clean up the floor plans.  I have a situation at this moment where I could use that feature.  Using version 9.1.
Tue, Jan 22, 2008 at 6:25:55 PM | break gridlines
rascal
I echo the desire to make gridlines able to break in the center - I've got an overly cluttered floor plan, so it looks like I'll have to revert to ACAD for this one.
dimensioning gridlines
Sat, Nov 4, 2006 at 10:27:59 AM
Gridlines
Fri, Aug 8, 2008 at 3:24:08 PM
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:49:59 PM
re-numbering gridlines
Wed, Mar 26, 2008 at 3:08:06 PM
Gridlines in front of Model / Linework
Tue, Jul 13, 2010 at 12:45:01 PM
Page generation time: 4.5524
