Forums >> Workflow & Implementation >> Worksets >> Managing worksets
Tue, Jan 25, 2005 at 11:23:08 AM | Managing worksets
constantine
I'm fairly new to Revit, and have found that working alone on a project is much faster (to an extent) than most cad programs I've come across, there is however a specific set of issues that I can't quite grasp when it comes to the concept of "worksets" and "central files", "Local Files" and other such things. can anyone point me in the right direction for a tutorial on these issues. also, if anyone has found the feature countrproductive, would you mind sharing what problems have arisen from using worksets?
I dont mean to sound bitter, cold, or cruel, but I am, so thats how it comes out. Bill Hicks.
Thu, Feb 3, 2005 at 7:09:38 PM | RE: Managing worksets
Birdman
I have found worksets invaluable when working in a team but they do take a lot to get used to and a bit of planning helps as well. You basicaly need to save a 'Central File' that everyone references and keeps up to date (a bit like a central xref), then you work from 'Local Files' saved on your local drive. Whenever you save your local files you can also save to the central file, others can then update their files with changes you have made. Try the 'Sharing Projects' tutorial in the Revit help.
Thu, Feb 3, 2005 at 9:23:01 PM | RE: Managing worksets
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Worksets are very temperimental and it is critical they are completely understood before use. It helps to sit down and work out exactly how you want to break up the building, shell, core, fitout, unit walls etc. etc. There are some good threads on the augi forums about best practices using worksets... Check them out. HTH.
Worksets
Wed, Feb 8, 2006 at 1:12:31 AM
Display worksets by color
Tue, Jun 17, 2008 at 11:54:46 PM
Managing Links
Wed, Jul 28, 2010 at 4:48:23 PM
At what stage do you know when it's time to break up a model?
Mon, Dec 12, 2011 at 1:24:57 PM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
Page generation time: 0.0466
