Forums >> Revit Building >> Technical Support >> Extract .pat ( hatches) from a cad drawings to put into my REVIT Template
Sun, Jul 29, 2007 at 6:42:54 PM | Extract .pat ( hatches) from a cad drawings to put into my REVIT Template
Formfunction33
Is it possible to take hatches from a sample CAD file to put into the REVIT model?  In general ,REVIT fill patterns are pretty much no fun.
Sun, Jul 29, 2007 at 8:50:41 PM | Extract .pat ( hatches) from a cad drawings to put into my REVIT Template
psymon
psymon Avatar
3.5 Stars: 6 Votes
Have a look at the tutorial: "Creating and Applying Fill Patterns" in revit 2008.
You can import an Autocad .pat file into Revit. I do not know if you can export a hatch pattern from an Autocad Drawing though. I think you need the original .pat files.
There are a few fill patterns on this website.
Mon, Jul 30, 2007 at 1:34:42 PM | Extract .pat ( hatches) from a cad drawings to put into my REVIT Template
sdbrown
5 Stars: 3 Votes
revit uses any .pat file you have, open the revit.pat file and read its instructions. Basically there is a small line of code you add to a pattern to specify it as a model pattern.  Here is my .pat file for you to start with.
Errors with hatches in imported cad files
Wed, Mar 14, 2007 at 3:16:31 PM
reloading updated template....?
Tue, Dec 16, 2008 at 12:07:45 PM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
Exporting to CAD from Revit 2012
Mon, Aug 26, 2013 at 7:23:00 AM
Material hatches
Wed, Feb 22, 2006 at 1:49:20 AM
Page generation time: 1.5710
