6 Users Online (5 Members):
Forums >> Revit Structure >> Technical Support >> Need Revit structure 2 for researching
2 Posts No Rating |
anyone who can shows me the link to down load free, I want to research something relating to Revit and Etabs. So firstly I want to try with RS2 , and then I will try with the latest one
10 Posts No Rating |
here ya go... but, if you get something to work in Rev2, don't think it will reproduce the same way in 2008  http://revit.autodesk.com/Structure/2.0/common/download.asp?en-us
Hi there, you mean to say Revit Structure 2 & RAC 2008 is not 100% compactible but still can be used? I am thinking of trying out exporting a RAC 2008 into Structure 2. What about Revit 8.1? Will I get better result with 8.1? Thanks.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
You can bring an older revit file into a newer Revit program, but not the other way around. The newer Revit program will just update the older file for you when it is imported. So, no you can not bring a RAC 2008 file into Revit 2. Revit 2 will not know what an RAC 2008 file is. If you use Building 8.1, then you would need to use at least Revit 4 to import that file.
Metalic Structure in Revit Architecture |
Fri, Dec 3, 2010 at 1:10:10 PM
Modyfing columns in Revit Structure |
Thu, Nov 1, 2007 at 12:55:53 PM
Revit STRUCTURE |
Fri, Jun 17, 2005 at 2:45:21 PM
Hello All! Moving Revit Arch Drawing to Revit Structure Problems |
Thu, Feb 12, 2009 at 8:18:59 AM
Need HELP!! Geting a Navisworks file inn to Revit Structure |
Mon, Apr 8, 2013 at 8:02:00 AM
