Forums >> Revit Building >> Technical Support >> floor slab edge
Thu, Jul 26, 2007 at 8:39:35 PM | floor slab edge
yoiyoi
how do i create a monolithic floor slab with a thickened edge.
the floor slab edge sweeps ends up with  two different 'pieces'
responses appreciated
Fri, Jul 27, 2007 at 9:56:21 AM | floor slab edge
wayline
you are not specific enough - a 3d screen shot could really help.  see that you are not choosing to sweep alon the top edge of the slab on one side and the bottom edge on the other...hth
Fri, Jul 27, 2007 at 10:05:04 AM | floor slab edge
JHanby
3.5 Stars: 3 Votes
Did you try to join the floor sweep with the floor slab?
Thu, Aug 21, 2008 at 11:02:12 PM | floor slab edge
rlwells
I had the same problem using a 6" concrete "slab" for the floor. I replaced the "slav" with a generic 4" concrete floor and the floor slab edge sweep joined to the floor without a problem.
Fri, Aug 22, 2008 at 3:31:34 AM | floor slab edge
4 Stars: 205 Votes
Hi, put some screen shots about what do you need and want so we can figure it out....
Floor slab edge not joining right REV2008
Tue, Aug 14, 2007 at 3:37:07 AM
adding radius edge to floor slab
Wed, Jul 21, 2010 at 7:47:29 AM
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
Composite floor edge
Mon, Oct 1, 2007 at 8:38:41 AM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:42 PM
Page generation time: 0.9739
