18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Resize 3d view on a sheet
24 Posts No Rating |
Is there a way to resize a 3D perspecitve view on a sheet without actually moving the camera? I have a series of views that are all the same of several design options, but the client has selected one of these options so I want to make their selected option larger while still showing the rest. Any ideas?
yeah, that's a tough one to find. you have made a camera view right? and it's perspective instead of anoxemeric or whatever it's called LOL. I'm assuming you want to enlarge the view of your camera view on your sheet. So, go to your sheet with the 3d perspective view. Click the screen, then right click and select activat view. Then select the "dynamically modify view" button (the eyeball with 3 arrows) or press F8 if you haven't changed your keyboard shortcuts and this opens up a dialog box for your dynamic view in the bottom left corner of your viewer. Now select the "field of view" tab and select whatever you like to create your excellent 3d perspective view for your clients.
That works just fine! Thanks a lot!
...or: just click on your view on the sheet, on the top bar, right to the property button you should hve one that says Size and displaying current size, click on it and it will open the dialogue box, you can change field of view, or in your case scale. simple...
1 Posts No Rating |
:o)
Resize Floor plan view on sheet. |
Tue, Aug 2, 2011 at 7:03:17 PM
Copying Sections to a revision sheet |
Fri, Jun 6, 2008 at 9:32:48 AM
Resizing Viewports on a Sheet |
Fri, Jun 5, 2009 at 11:32:06 AM
View in sheet |
Mon, Feb 6, 2006 at 2:19:24 PM
can resize floor sketch |
Sat, Aug 23, 2008 at 5:06:01 AM
