27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> revit 9: light fixtures
i put what revit im using but i dont know if that is where it goes. anyway, i want to know how to make light come from a fixture i made in revit. i see all the other light fixtures that i download, and when you render them, it looks like light is actually coming from them. but when i make it, the "bulb", or the object that i use, only sort of glows, and not like the other ones on here. please help
Check the lumens in the properites. TIP:A lumen indicates the amount light emitted from a light source. For incandescent lights, the ratio of lumens to watts is approximately 17 to 1. For fluorescent lights, the ratio is approximately 60 lumens to 1 watt. If you do not specify a value for lumens, Revit Building uses a default value of 1700 lumens, which is approximately equal to a 100-watt incandescent bulb.
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
turning on light fixtures |
Wed, Oct 16, 2013 at 10:53:10 PM
Face Based Light Fixtures |
Tue, May 12, 2009 at 5:57:35 PM
Turning Off Light Fixtures In Linked Model For Rendering - How To? |
Mon, Jun 20, 2016 at 3:57:36 AM
The lighting fixtures wont show up in my final revit 2013 rendering. |
Wed, Jul 31, 2013 at 3:23:18 AM
