Forums >> Revit Building >> Technical Support >> Windows in Battered Walls
Tue, Jan 25, 2005 at 9:29:12 AM | Windows in Battered Walls
Osir
I have tried two different methods to create a wall with thicker bottom (18"Winking than top (6"Winking (inside of wall is vertical, outside of wall slants) . In each, the wall comes out fine, but I can not get windows to insert into the wall. Any ideas why I wouldn't be able to do this? I have tried making the walls with In-Place family Sweeps, In-Place family extrude and void sweep. Also, I have made sure that I am creating the In-Place families as wall families. Post edited on 2005-01-25 12:53:53
-IOeser
Fri, Jan 28, 2005 at 1:13:42 PM | RE: Windows in Battered Walls
Osir
A local user answered my question... I needed to insert windows/doors in an ELEVATON VIEW, it doesn't work in plan view when you have an in-place wall family. Another local user provided these written instructions for making a battered wall (see attachment): 1) create an in-place family using the wall category (as you mentioned) 2) select solid blend, then draw the bottom and the top surfaces. for the height, I changed the depth of the blend to 12' -0" 3) make sure to say finish family 4) finally, place doors and windows ( you will need to modify the frames so that they are not there or adjust to the angle of the wall - use reference lines for this)
-IOeser
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:01 PM
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:50 PM
Can't figure it out, Windows are not cutting my walls
Fri, Apr 30, 2010 at 12:39:16 PM
Windows and Furred out Walls
Wed, Oct 14, 2009 at 7:47:11 AM
curtin walls to windows....
Tue, Sep 2, 2008 at 7:06:30 AM
Page generation time: 0.4576
