Forums >> Revit Building >> Technical Support >> Batt Insulation
Thu, Jul 26, 2007 at 9:39:58 AM | Batt Insulation
arch00
Please advise on how i can get a batt insulation pattern in my drawing. Downloaded the hatch pattern but it does not import. Tried to open the file but error message indicates that it needs to be manually imported. What does that mean.
Thanks
Gar
Thu, Jul 26, 2007 at 9:41:39 AM | Batt Insulation
broncos4life
3.5 Stars: 11 Votes
Why not just use the Insulation tool?
Thu, Jul 26, 2007 at 11:48:44 AM | Batt Insulation
arch00
Ended up doing that, but was hopin to get the right pattern associated with the wall so I don't have to draw it in all the time.
Thu, Jul 26, 2007 at 12:19:54 PM | Batt Insulation
sdbrown
5 Stars: 3 Votes
You would need to create a material with the pattern you've found. then edit your wall type to have that material as the core, ie a material called Stud - Insul filled.
Fri, May 16, 2008 at 5:48:56 PM | sdbrown
rlawson
Quoting sdbrown from 2007-07-26 12:19:54
"You would need to create a material with the pattern you've found. then edit your wall type to have that material as the core, ie a material called Stud - Insul filled."
The only problem with this is how to mark the identity information (keynotes, etc) for both the studs AND the insulation. They are sharing the same position.
Batt Insulation Blanket
Wed, Aug 27, 2008 at 12:39:31 PM
More batt insulation options
Fri, Nov 21, 2008 at 11:50:55 AM
Batt Insulation in barrel roof
Mon, May 30, 2016 at 8:08:11 AM
Insulation in Families
Mon, Dec 8, 2008 at 2:50:57 PM
Batt insulation
Thu, Oct 20, 2016 at 2:09:37 PM
Page generation time: 1.8792
