Forums >> Revit Building >> Tips & Tricks >> Ramp breaklines
Thu, Jul 26, 2007 at 12:39:17 AM | Ramp breaklines
duckbuild
Can Revit automatically do breaklines and dash the hidden part of the ramp above like it does with stairs?... Or do I have to  do a masked region in dashed lines with a brekline squiggle on it?
Thu, Jul 26, 2007 at 6:18:20 AM | Ramp breaklines
Why do you ask this?  Seems to me that all you have to do is look at your ramp plan ....
Did you notice that the ramp is cut horizontally at the level of your view just as all the rest of your model is cut. Notice that this moves up and down the ramp relative to your view level set in the VP.  If you want a break line, you will have to add it.
Wed, Nov 25, 2009 at 5:32:02 AM | Ramp breaklines
spook77
5 Stars: 2 Votes
this is a problem that many people are asking about. i can't get the ramp to show the cut, like stairs do... even though i've checked the project settings, and ramps show an option for cutting and overhead dashed lines, just like the stairs. even though i've built a ramp that goes up to the level above, it just shows it uncut in the plan view.
is there a hidden setting somewhere that allows ramps to be cut like stairs do?
Wed, Nov 25, 2009 at 6:47:22 AM | Ramp breaklines
If your ramp is a Revit ramp, not a mass or something else, it will be cut at the level of the view cut plane.
Fri, Nov 27, 2009 at 5:14:38 AM | Ramp breaklines
spook77
5 Stars: 2 Votes
unfortunately this is not the case for me, (i'm using revit architecture 2010 with all the default view settings)
when i make a revit ramp go all the way to the floor above (ex. car garage ramp), it does not cut in the view like the revit stairs do. it also looks like everyone else but you in the forum has the same experiance i am having,  and the only solution is that you have to use a region over the ramp, and then manually draw the breakline...
how are you getting your ramps to display the breaklines like they should?
Fri, Nov 27, 2009 at 8:55:59 AM | Ramp breaklines
I'm sorry - looks like Ramps don't cut in 2010.  I think I may have had the same problem in 9.1 so I used a sloping floor for a parking garage ramp.  I just checked that and it cuts in 2010.
Tue, Apr 16, 2019 at 5:37:49 AM | Ramp breaklines
WarehouseMO
It is still a problem even in 2019...
How to do breaklines?
Mon, Feb 9, 2009 at 8:09:15 PM
breaklines
Thu, Feb 28, 2008 at 10:56:30 AM
Breaklines print out with a big masking block attached... Help!
Thu, Apr 28, 2005 at 10:22:15 PM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:09 AM
Page generation time: 0.0425
