Forums >> Revit Structure >> Technical Support >> Tags
Wed, Jul 25, 2007 at 1:20:51 PM | Tags
Jordan14
I am trying to create a tag to show the beam reactions, and I am running into some trouble. I have created a generic tag, but it won't seem to actually tag anything. Does anyone know how to make a generic tag tag a beam? I am also trying to get a generic tag that I made tag a detail component, but since it is not a detail item tag, it is not working. Can you load a generic tag as a detail item tag, and if not, how do you make a detail item tag?  Thank you in advance!
Wed, Jul 25, 2007 at 4:24:38 PM | Tags
TJKENNEDY
3 Stars: 2 Votes
I created a new Structural Frming Tag, starting with the generic tag template. I made some shared parameters that I loaded into my project and the tag family, so I can put the reactions in the beam properties. I attached the tag family, but I dont know if it will work right for you because of the custom shared parameters.
Thu, Jul 26, 2007 at 9:21:39 AM | Tags
Jordan14
Thank you for your response. I have made a similar tag using the multi category tag. How did you get the generic tag to know that it was a structural framing tag?
Thu, Jul 26, 2007 at 10:09:34 AM | Tags
TJKENNEDY
3 Stars: 2 Votes
In the tag family, go to Settings|Family Category and Parameters. Then scroll down and select Structural Framing Tags.
Thu, Jul 26, 2007 at 3:16:28 PM | Tags
Jordan14
Thanks! That is exactly what I was missing.
tags tags tags
Tue, Mar 20, 2012 at 12:10:23 PM
Tags linked in more than one view
Fri, Feb 27, 2009 at 6:21:47 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
MISSING elevation tags
Mon, Sep 17, 2018 at 10:55:17 AM
room tags
Thu, Aug 13, 2009 at 3:54:34 PM
Page generation time: 0.0852
