10 Users Online (8 Members):
Forums >> Community >> Newbies >> rotate sweep
3 Posts No Rating |
HiStill trying to solve family problem. Trying to attack from another direction. I create a sweep, but instead of using a profile I use sketch profile. Problem is now I don't get a parameter for angle and I can't seem to get angle to work. Any help would be appreciated bob v
Hi Bob, could you explain further what it is that you are trying to acomplish?????
Are you trying to create a family with a parametric angle? If you try to do it with a sweep, you'll have to constrain just about everything except the angle that is parametric, and you'll need to create a new parameter for the angle. (dimension the angle, then create a new label for it. Then in the family types, you can set how the angle will change in each preset family type.) Is this what you're trying to accomplish? Best of Luck, Ruth
Ruth Rau Main Street Architecture, P.C. |
Rotating Sweep Families |
Wed, Apr 4, 2007 at 10:28:49 AM
ROTATE ELEMENT |
Mon, May 16, 2011 at 8:15:08 AM
3d sweep |
Tue, Apr 3, 2007 at 3:13:42 PM
3d rotate |
Fri, Sep 28, 2018 at 7:16:26 AM
Can You Flex a Sweep in Components |
Mon, Jun 3, 2013 at 2:09:23 PM
