24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> metal wall panels with rivets at the corners
6 Posts No Rating |
We are attempting to create a grid of metal wall panels with rivets at the corners. To make things more complex, they are on walls that are not perpendicular to the horizontal plane. We found a download, but it failed horribly. Any ideas on how to model this?
Ok, first make a curtain panel in the shape you want, next make a rivet family(generic model), nest the rivet family into your curtain panel family, and array it as needed(note you can add a parameter to array so you can increase the count if your have diff. panel sizes. then to create the wall not horizontal, either create a mass first , then use wall by face or use a ruled curtain system.
metal wall panels |
Mon, Nov 29, 2010 at 10:36:25 AM
Need rendering material for metal roof and metal wall panels. Red paint finish. |
Thu, Oct 26, 2006 at 5:09:26 PM
wall corners to automatically create extrusion |
Tue, Nov 28, 2017 at 8:30:09 AM
Raised Glass/Metal Panels for Curtain Wall |
Thu, Dec 20, 2007 at 6:43:04 PM
metal panels |
Mon, Dec 20, 2004 at 6:01:44 PM
