Forums >> Revit Building >> Technical Support >> Overhead doors in Stacked walls
Tue, Jul 24, 2007 at 3:36:31 PM | Overhead doors in Stacked walls
MongooseST7
MongooseST7 Avatar
I am using Revit 9.1. I downloaed the overhead door 3343 that has an adjustable width and has windows in the door. This door is similiar to industrial loading dock doors. I have a stacked wall that I am placing it into. The wall is a 1" Metal panel wall similiar to a pre engineered building wall over top of an 8" concrete cast in place wall running about 18" up like a knee wall. The wall is about 18' tall. When I insert the door into the wall I am getting the following:
Instance(s) of 10' Wide not cutting anything.
Can't make type "Overhead_Service_Bay_Door_3343 : 10' Wide".
None of the created elements are visible in Floor Plan: First Level View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I have checked the visibility settings and they have remained the same throughout the project. The only thing I changed was the wall from a plain metal pre engineered wall to the stacked wall and when doing so none of the old 3343 doors were able to be placed back into my stacked wall I have to go through an put them all in again.
 Any thoughts out there or tips?
Tue, Jul 24, 2007 at 4:24:53 PM | Overhead doors in Stacked walls
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Thanks for bringing that to my attention. Try this one.
Rolling Overhead doors in Schedule
Thu, Dec 23, 2010 at 6:57:39 PM
Overhead doors in schedules
Fri, Jan 30, 2009 at 2:02:34 PM
overhead lines
Tue, Jun 3, 2008 at 5:23:47 PM
stacked walls
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls
Tue, Nov 25, 2014 at 5:51:10 PM
Page generation time: 1.6138
